Italics in Part Studio Features panel, what does it mean?
I have a situation with a part I am working on in Part Studio. In the Features panel, past a certain point items are listed in italics. Firstly, this is NOT things having hidden visibility like with planes and sketches - it's something different. When you go to edit the item, it doesn't show any of the configuration in the dialog panel for that feature. So for example, associates elements don't show. They aren't missing per se and the feature still works. You can also add or change things and this takes. But those don't show up either if you go back and edit it again. Even adding new elements all start out this way. If you delete an element and recreate it, it's still stuck in this mode.
I can find no reference to this anywhere. Is there a setting or something that I could have accidentally toggled? Is there some element with some sort of error somewhere? I'm not getting anything in red or saying it didn't generate, so I don't think there is an error somewhere.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,422
    Are you in rollback mode? Is there a bar above your features in italics? This is used to insert features before others. Right click and select roll to end.
    joseph_illingworthjoseph_illingworth Member Posts: 2
    I have this issue, and it's really urgent. Everything after trying to extrude the face of the mirrored part is grayed out and italicized. Cannot create sketches on face of mirrored part now, and when I select the face to extrude it says "face of mirror 2" instead of "face of part 14" and fails to retrieve any of the info I orginally put into the feature when I made it. Absolutely no functionality right now.
    The list down the left is time or history dependent - when you edit extrude18 the other features do not exist yet
    No, they were all grayed out even when I wasnt inside the extrude 18 dialogue box. But a couple hours later I reopen the document and it works. Who knows :/, maybe a glitch
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    The features might have been in the process of regenerating after you had edited the feature.
    When they are regenerating, they show as greyed out.
    lamar_dunlaplamar_dunlap Member Posts: 1
    Has anyone given a good answer as to why the Features panel has some items italicized and in grey. I ask because the functionality of the features aren't working while in this grey state. Is there a way to get it back to normal?
    @lamar_dunlap are you in rollback state? You may see a grey bar above the grey features - right click and select roll to end.
    @lamar_dunlap
    If you aren't in rollback state (there is no grey bar above the greyed-out features), the greyed-out features may be in the process of regenerating. The process of regenerating can take a while.
    robert_scott_jr_robert_scott_jr_ Member Posts: 326 ✭✭✭
    Refreshing browser worked for me. - Scotty
    Object_MageObject_Mage Member Posts: 13 EDU
    I had the exact same issue and refreshing the browser worked for me to. Shouldn't have to refresh the browser constantly thats annoying.
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    This happens to me as well from time to time. I chalked it up as a glitch, as everything behaved normally except the features were grey/italc..
    Hard to repeat. But if it hapens again i'll try and retrace my steps and find at least one cause.
    The features will show in grey if they are in the process of regenerating.  This should be accompanied by a spinner, so if there is no spinner it is definitely a bug.  Refreshing fixes this because the feature list/geometry data won't be sent until the regeneration is finished, so the feature list you receive (upon reload) must already be done regenerating by the time it gets to you.
    chris_fehringchris_fehring Member Posts: 2 EDU
    I just had the same problem with a variable that I just added and then moved up towards the top of a part with lots of features, some of which depend on the variable.  Features weren't in the process of regenerating (no spinner).  Browser refresh fixed the issue.
    @chris_fehring @john_mcclary and others in this thread,
    I spend some time trying to reproduce this and was unsuccessful.  If you can come up with reliable reproduction steps, please post them here.
