Named dimensions, using in equations
Tome
Member Posts: 1 ✭
What a great start to a CAD system. Love the collaboration and mobile capabilities especially. Keep up the good work!
I would like to see named dimensions and the ability to use them in equations to define geometry. This, and projecting geometry to planes and other geometry are two features I commonly use and find lacking in OnS. Thanks,
-Tom
-Tom
3
Something like =D1, =(D1+2) I did go looking with the new release. Current I am doing this by manually inputing into the expressions, was very excited to see the "change to driven dimension" turn up in the latest release, thats a step in the right direction.
And although it's clearly not a case of the glass already being half full, I think the existing embedding of input mathematics in dimension entry is elegantly minimal.
I reckon it's a great example of one of the guiding principles of Onshape's interface design: doing more, and doing better, with less.
As a workaround, you can add a sketch to do maths with, using lines, equal relations (both within the sketch, for addition and multiplication, and to bring data into or out of the sketch), symmetric constraints, similar triangles for proportion, right triangles for trig etc.
As well as using the fact that multiplication is just repeated addition, it may also be useful to reflect that division is no more than repeated subtraction with (usually) a remainder.
Aside from those things, and hoping some day I can use OnShape on my Android tablet, I really enjoy OnShape! Love it!
Aaron
Regarding the second "feature" you mention, I imagine you're aware of the workarounds using "extrude", as a surface?
For instance, to project a sketch to another sketch, or a set of faces, or a surface...
