What happened to clara.io?
 exworks
                    Member Posts: 3 ✭
exworks
                    Member Posts: 3 ✭
             lougallo
                            Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 lougallo
                            Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 @exworks Clara decided that supporting the Onshape integration was not worth it yet and would reevaluate this integration in the future. If you would like to voice your opinion on this, you should probably reach out to them and tell them you want the integration to come back to Onshape.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5 @exworks Clara decided that supporting the Onshape integration was not worth it yet and would reevaluate this integration in the future. If you would like to voice your opinion on this, you should probably reach out to them and tell them you want the integration to come back to Onshape.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
             joe_dunne
                            Onshape Employees, Developers, csevp Posts: 198 joe_dunne
                            Onshape Employees, Developers, csevp Posts: 198 I am not sure I would have worded it that way. They did indeed decide to turn off the free only version of their product. They found a bit hard to maintain support and maintenance of a free only product. I have encouraged them to consider offering a pro level product. Hopefully in the future they will be able to allocate resources to do so. I am not sure I would have worded it that way. They did indeed decide to turn off the free only version of their product. They found a bit hard to maintain support and maintenance of a free only product. I have encouraged them to consider offering a pro level product. Hopefully in the future they will be able to allocate resources to do so.
 If you are looking for an alternative Integrated Cloud Application for visualizatiopn, I would highly recommend 2 products:
 OneRender
 RealityServer
 Each of these offer great capabilities. Each are constantly updating and improving their products.
 Keyshot as well is a great application. Although it runs on the desktop it support native MacOS and Windows installs.
 Joe
 Joe Dunne / Onshape, Inc.5
OneRender
RealityServer
Joe
I've messed with claira.io and RealityServer is much better and easier to use
"There was an error while trying to load the scene.
Was nice while it lasted.
While the new interface has some more complexity to it, unfortunately it was necessary if we were to incorporate the feature requests we were seeing from the users (and give room for other features we plan). However we have tried to lay it out such that you don't need to use the complexity if you don't want to. There are lots of settings you can tweak but you don't need to touch them to get good results. You can just drag and drop materials onto parts (and you can search materials now, a very frequently requested feature) and leave it there if you like.
Also, if you don't like the clutter when reviewing your rendering, there is a little maximise button in the top right of the viewport so you can hide most of the user interface to get a better view of your model. Of course, that will also be covered by the video when we have done it.
I won't try and cover the new interface in detail here since that is best left to the video we are working on, however if anyone wants to get moving more quickly we'd be happy to setup a 1:1 with you if you get in touch with us.
@AuroraRon if you are able, it would be great if you could reach out to us on support@migenius.com to run through the issues you are having, we'd be happy to compensate you with some rendering time for your help.
When I was dragging materials onto parts, their appearance didnt change.
I had to manually do it
For manually doing it, how did you go about that, select the object from the scene graph then right click on the material and press Assign to Selection?
I've been doing a lot of testing myself today and found a few cliches which we are working on fixing over the next few days.
When I was manually doing it, I was selecting the part from the pane at the left.
if I clicked in the graphics area on a part, it only selected a face
In all seriousness, we are actively working on issues I saw today, for example for me saving was failing the first time (but succeeding after that), quite a lot of material assignments were resulting in pink materials the first time but the second time worked and a few other things I noticed. We'll probably be pushing updates more or less daily for the next week or so while we iron these bits out.
A bit like before, when it wasn't wanting to save to onshape
https://forum.onshape.com/discussion/8397/realityserver-for-onshape-q-a
I would encourage those interested in RealityServer to continue discussions there since we will monitor that thread with greater frequency. As a bonus for heading over there now, there is already an answer there on how to enable the new AI Denoising feature which can in some cases cut render time by a factor of 10 (ymmv of course).
