What happened to clara.io?
exworks
exworks Member Posts: 3 ✭
Will it come back?
  • john_mcclary
    joe_dunne said:
    I am not sure I would have worded it that way. They did indeed decide to turn off the free only version of their product. They found a bit hard to maintain support and maintenance of a free only product.  I have encouraged them to consider offering a pro level product. Hopefully in the future they will be able to allocate resources to do so.
    If you are looking for an alternative Integrated Cloud Application for visualizatiopn, I would highly recommend 2 products:
    OneRender
    RealityServer
    Each of these offer great capabilities. Each are constantly updating and improving their products.
    Keyshot as well is a great application. Although it runs on the desktop it support native MacOS and Windows installs.
    Joe
    Good call on RealityServer
    I've messed with claira.io and RealityServer is much better and easier to use
  • brucebartlett
    Reality Server is my goto app for rendering on the rare occasion I need an image. Takes a little getting used to but I still seem to able to get something half decent without really knowing what I am doing. I am looking forward to some more reality server improvement in 2018 and thanks @paul_arden for the updates is 2017.
  • Paul_Arden
    Paul_Arden Member, Onshape Employees, Developers Posts: 228 image
    Keep an eye out for something new with RealityServer very soon! Hint.
  • AuroraRon
    AuroraRon Member Posts: 141 PRO
    It does not work at all now.
    "There was an error while trying to load the scene.
    unable to set root group on scene"
    Was nice while it lasted.
  • AuroraRon
    Looks like Reality Sever did some updates and you can switch to the old interface but it went from simple to complicated.  Caught me by surprise when I went to use it and my models no longer load. The new interface needs some instruction.  Has anyone been able to get it working?
  • Paul_Arden
    We did test with previously saved models in both the old and the new editor and it worked for us but we may well have missed something. We are working on a video for the new interface which we hope will help people get started with it that's one reason we left in the option to allow users to continue with the old application for now. However we had quite a few people desperate for the new features so we wanted to get the new one out there as well.
    While the new interface has some more complexity to it, unfortunately it was necessary if we were to incorporate the feature requests we were seeing from the users (and give room for other features we plan). However we have tried to lay it out such that you don't need to use the complexity if you don't want to. There are lots of settings you can tweak but you don't need to touch them to get good results. You can just drag and drop materials onto parts (and you can search materials now, a very frequently requested feature) and leave it there if you like.
    Also, if you don't like the clutter when reviewing your rendering, there is a little maximise button in the top right of the viewport so you can hide most of the user interface to get a better view of your model. Of course, that will also be covered by the video when we have done it.
    I won't try and cover the new interface in detail here since that is best left to the video we are working on, however if anyone wants to get moving more quickly we'd be happy to setup a 1:1 with you if you get in touch with us.
    @AuroraRon if you are able, it would be great if you could reach out to us on support@migenius.com to run through the issues you are having, we'd be happy to compensate you with some rendering time for your help.
  • MBartlett21
    @paul_arden
    When I was dragging materials onto parts, their appearance didnt change.
    I had to manually do it
    IR for AS/NZS 1100
  • Paul_Arden
    @paul_arden
    When you dragged it, what did the cursor look like? We have seen sometimes it takes a second or two after you start dragging for the cursor to change to the material thumbnail which means it's ready to drop on the material.
    For manually doing it, how did you go about that, select the object from the scene graph then right click on the material and press Assign to Selection?
    I've been doing a lot of testing myself today and found a few cliches which we are working on fixing over the next few days.
  • MBartlett21
    @paul_arden
    When I was manually doing it, I was selecting the part from the pane at the left.
    if I clicked in the graphics area on a part, it only selected a face
    IR for AS/NZS 1100
  • Paul_Arden
    @paul_arden
    The click to select selections should be by part, if it is picking surfaces then that would usually mean there are surfaces in the model instead of parts. A screenshot would help a lot if you can share one since I can't really visualise what you might be looking at.
  • MBartlett21
    For some reason, it is all working correctly now, not sure what happened.
    IR for AS/NZS 1100
  • Paul_Arden
    Magic :-)
    In all seriousness, we are actively working on issues I saw today, for example for me saving was failing the first time (but succeeding after that), quite a lot of material assignments were resulting in pink materials the first time but the second time worked and a few other things I noticed. We'll probably be pushing updates more or less daily for the next week or so while we iron these bits out.
  • MBartlett21
    @paul_arden
    A bit like before, when it wasn't wanting to save to onshape
    IR for AS/NZS 1100
  • Paul_Arden
    Just to note, I have created a new, generic RealityServer Q&A thread here:
    https://forum.onshape.com/discussion/8397/realityserver-for-onshape-q-a
    I would encourage those interested in RealityServer to continue discussions there since we will monitor that thread with greater frequency. As a bonus for heading over there now, there is already an answer there on how to enable the new AI Denoising feature which can in some cases cut render time by a factor of 10 (ymmv of course).
