Diagonal dimensioning in drawings
Hello, I am a newbee to Onshape. I am liking what I am discovering. But I, would like to know if there is a way to insert a diagonal dimension in the drawings process? It keeps jumping from horizonal, to vertical. Am I missing some trick?
Thanks
    edited March 2018
    I found it hard to get it to work recently when doing a drawing. Afer a few frustrating minutes, I found I had to drag up to the top right and it started working for me.  I had not experienced this problem before.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,002 PRO
    are you selecting the diagonal edge? or the two points of the diagonal?
  • terry_falldorfterry_falldorf Member Posts: 7
    John, Thankyou for the quick response. But I am trying to get diagnal from corner to corner of a rectangle to show the square of the rectangle. I think I'm going to have to draw a construction line from corner to corner and dimension that?
    THANKS AGAIN!
    THANKS AGAIN!
    @terry_falldorf
    You won't have to do a construction line, just move your mouse up to the far top right or far top left.
    It will then go diagonal and you can move your mouse back in.
