Any quick way to do a draft on a complex shape?
The only way I think I can do it is by a sketch at the base then thicken the edge then a sketch on the top surface and then use loft for each letter. - long process. I want a 10 degree draft.
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,145 PRO
I pulled this tab out of your doc Aaron.
https://cad.onshape.com/documents/ac752bc7974dc84df86b498e/w/4f422d2e9042c6a0df584696/e/3000233e0dd5756e247b3a92
I had a little play with the geo and I can only randomly get some of the characters to draft to 10 deg. I also tried using a 2 steps process with the neutral plane at the top and the bottom.
There need to to be a way to smooth the curvature on the side before adding draft
5
Have you tried extruding and choosing draft
https://cad.onshape.com/documents/28050bca2b1ddeb0acbab720/w/72369ffa7faabbf84de28ab1/e/962d51f42704f792bb517516
It may be helpful if you post a link to your doc. If you try to a draft after the fact (after the extrude) are there geometries that fail? Or is it just hard to select all the faces you want? As a shortcut to selecting all those side faces you could use the right-to-left box select mentioned on this page:
https://cad.onshape.com/help/Content/selection.htm
And do the box select something like this:
It appears to show the failing region if you're careful when selecting. my next step would be to edit this region.
Alternatively I need to manually adjust the letters geometry that the draft fails on.
