How to create BOM in part studios
lukas_szwugier
Member Posts: 11 PRO
Hello ONSHAPE community !
Anyone have a idea how to create BOM for multi body sheet metal part studio?
I have created multi body sheet metal part studios and i wondering how i may present it on drawing for shop floor guys.
Because of its complexity move it to assembly is not a option. I started from surface model and convert it to sheet metal parts.
Any ideas.
Any ideas.
john_mcclary
Member, Developers Posts: 4,001 PRO
There is no BOM for part studio. You will need to move it to an assembly.
may I ask why you cannot move it to an assembly?
Regardless of complexity, any single part studio can very easily be moved to an assembly and fully mated with about 7 mouse clicks.
7 -
john_mcclary
Here is a 2 and a half minute video where I create an assembly from 1320 parts: https://youtu.be/SXnqxH0zjUI7 -
lukas_szwugier
John i think you make my day sunny today
It is grate.
I was old CAD thinking i thought that i need put every single part to assembly silly me
Thank you very much.
john_mcclary
Yea that group mate is a real life saver. It will actually speed up your assembly in some cases: https://forum.onshape.com/discussion/comment/38234
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
Dropping parts in assembly and group mating as John just showed is also very fast to do on mobile. I had a large imported assembly and was able to put all the parts in assemblies, group and fix, all on my phone while traveling (wife driving) and I think the workflow was as quick or quicker than in the browser.0 -
owen_sparks
Member, Developers Posts: 2,660 PRO
Nice workjohn_mcclary said:Here is a 2 and a half minute video where I create an assembly from 1320 parts: https://youtu.be/SXnqxH0zjUI
HWM-Water Ltd0 -
john_mcclary
You have a few options
~Create a composite part
~Boolean your parts together
~Create an assembly, set the assembly to "show assembly only"
It is grate.
Because this creates a needless operation.
Ex: I have a part studio that has 4 unique parts in it. If I insert it into a larger assembly, even grouped, in the BOM they are listed as individual parts.
So now I have to create a new assembly that has the same parts as the part studio, and then I have to create the 10+ configs that the part studio has, in the sub assembly that was created from the part studio, then I have to do that all over again in the top-level assembly.
Or I could just insert the part studio, and have it called out as its own item in the BOM. But that functionality doesn't exist.
