How can I add a part in Isolated view?
jon_woellhaf
Member Posts: 92 ✭✭✭
When I isolate several parts, how can I add another isolated part?
As it is now, when I isolate nine parts and realize I omitted the tenth, I have to start over.
john_mcclary
Member, Developers Posts: 4,050 PRO
Try using the slider, it will select parts that are near your selection.
Otherwise if it is just 1 specific part, you will need to start over
5
Maybe we just need another improvement request
In solidworks I would use Isolate constantly to temporarily hide parts so I can select a hidden face to mate to.
OnShape makes me use hide other parts instead to get the same result, but then right click and show all parts. Isolate won't let you "click through" any transparent faces like in solidworks, so it is for visual stimulation only
Thanks @brucebartlett for pointing that out
