Transforming derived sketches
I'd like to align an derived sketch to the part in a PS. Is there a way to do it? It can be done easily with derived parts but not sketches.
In v3 of Transform pattern feature I added support of sketch bodies, so I think now it covers your requarements.
2
Derived sketches maintain their link positionally to the original. I am sure this is on purpose for 'top down' design. The workflow is - make & derive layout sketches which are stable to drive size & position in new part studio.
On the other hand derived parts can be independent positionally; only their features are linked.
Or perhaps Copy sketch entities could give you what you are after. Of course that breaks the link to original...
Using the source parts as derived parts and then deleting them seems like overkill, so is making a custom FeatureScript for something as simple as the reference sketch for a cut and a few holes.
Seems like you could be using assembly. You can insert sketch multiple times as needed, position to geometry or mate connectors, then the parts can be mated to sketch, and finally use in-context and copy parts in place in another part studio.
It will be helpful to share a link showing your intent and folks on the forum will jump in to help.
While a little more complex, you'll save time with the translations as it's more easily defined in an assembly.
Remember, when doing incontext-ing, you can double the component in the assembly feature tree, this creates a ghosted image of the assembly while in the part studio. This is hard to describe, but it's the most impressive feature when designing incontext and it's brilliant. I just wish I could update the context even though I haven't made an incontext assignment.
In any case, you made a generally useful feature. Thanks a lot…
