What drawing standards support do you need first?
Onshape Employees Posts: 56
edited July 2016 in Drawings
Please tell us your priorities for standards support in Onshape drawings.
While we are still improving our support for ANSI and ISO drawing standards, we are also looking to support what's unique to ISO variants such as JIS, DIN, GB, GOST, BSI, AS 1100, etc.
While they're mostly the same, differences do exist, such as in the appearance or behavior of BOM Balloons, ordinate dimensions, detail view borders, section lines, relative text sizes and more.  Some differences are more essential than others, and that's where we need your feedback.
Please let us know which of your standard's unique ways of doing things are most important to you, so that we can properly prioritize them.
  • Member Posts: 1
    JIS please
  • Moderator, Onshape Employees, Developers Posts: 1,646
    Hi @bui_quoc_phong
    Nowadays we do all our Improvement Request tracking through the 'Improvement Requests' section of this forum.  If you would like to see this implemented, please go to that section using the navigation in the side bar and submit an improvement request for JIS support in drawings.
  • Member, OS Professional, Developers Posts: 2,055 ✭✭✭✭✭
    ISO third-angle projection
  • Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
    This easily obtained with by either selecting when creating drawings or making your own templates with this setting
    @brucebartlett
    If I do that, then save it as a drawing template, the decimal separator always turns into a comma and I have to go into the drawing properties for every drawing I make
    You shouldn't have to, Mine works ok
