Prevent Part Studio From Rebuilding with certain configurations
MBartlett21
Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
I would like to be able to stop the Part Studio from rebuilding when certain configurations are selected.
Yes to your first statement.
I can't make the second behaviour work, because I can't use delete part on SM parts
For deleting sheet metal parts, you have to "finish" them first in FS. Here's an example that does this -- it deletes everything if the configuration is wood and anything over 20 inches. Note that I used the new configuration FS id editing functionality to make the internal ids match the names for the configuration inputs: https://cad.onshape.com/documents/ebba8f836a72a78d77c9174e/w/b13c08d970512acdbdb10f26/e/b83e350f778196726eed5eac
