Blocks?
Edward_Goodwin
Member Posts: 25 PRO
I've imported a dxf drawing into a sketch in an onshape part. As with SW, the lines in the drawing are not constrained to one another. In SW I'd normally create a block and then move/constrain the block itself prior to working with it as part of a sketch. How should I do this in OS? Thoughts? I simply want to group/constrain an imported drawing within a sketch such that I can use the geometry. I need to move the imported drawing such that it's correctly positioned within the part.
Thanks in advance! Edward
By highlighting the sketch entities, right-clicking and selecting transform, you will be able to move the sketch components to position as you desire. You should see a manipulator with arrows and a center circle that you can use to move the sketch components around.
Twitter: @bradleysauln
The good answer is you can do exactly as you want. The secret is in the circle of the transform manipulator. First you move that circle to the part of your geometry you want to reference from, then drag the whole lot and drop that circle onto the existing geometry you want to be coincident with. Does that make sense? It's one of those things that difficult to put into words, but simple to do once you know it's there.
Cheers,
@NeilCooke Did an excellent short video for exactly what I think you are asking. See it here.
