Can I extrude with offset from the sketch plane?
WeiLin_XingMobility
Member Posts: 3 ✭
Hi all,
I'm just curious with the extrude feature. I was wondering if I can extrude a sketch offset from the sketch plane? Whenever I need to create a solid off from the sketch plane I need to extrude(add) the sketch and extrude(remove) the length I want to offset from the plane. I remember this being an option in SW so I was wondering if there is an option in Onshape to allow me to perform the same action; instead of making two extrusion.
1
You can do this with the "second direction" of the extrude
https://cad.onshape.com/documents/877099f0f77be0567485ab3c/w/2da6c7bf59c426c3d303ead1/e/dc95ce633f1013706994fe16
In this example I created an extrusion from an equidistant one face to another equidistant to another face
