Creating a drill angle
jordan_lindsey
Member Posts: 3 ✭✭
Hey guys, quick question. I am working on a drawing for a friend and essentially he has a 19mm hole that is being cut 10mm deep, then he has a 10mm thru hole in the middle of the 19mm hole, so I guess more of a counterbore. He needs a 118 degree angle but I can't figure out how to do it. I attached the picture. Where I'm at is in black, and red is what needs done. Any help is appreciated! Thanks.
While on the subject of holes, when is Onshape going to allow tapped holes to have custom chamfers or counterbores while retaining tap information?
Brian
If it needs to be kept as a hole feature then why not create 2 holes as per the specified requirements? One hole 10mm thru and one hole 19mm blind?
