convert simple imported sheet metal model into Onshape doc
bryan_lagrange
Member, User Group Leader Posts: 803 ✭✭✭✭✭
in General
Currently Onshape does not have the ability to automaically convert an imported sheet metal model into and Onshape model that can be flatten (crossing fingers that this becomes a feature soon ) Here is a work around that I did on a simple sheet metal bracket. Granted this is a simple model and more steps will be needed to do a more complex model. I aslo did not use any convert to surfaces which would probably be another way to do this.
Step one import model:
Step 2 delete existing radius (use delete face command) of imported model so you have sharp edges to work with.
Step 3 select the sheet metal command. Select thicken and pick the face with the most geometry to convert.
Step 4 use the flange command and use the imported model to extend the flanges to the extent of the imported model.
Step 5 repeat the process until all entites have been added to the new sheet metal part.
Here is the link to the public document.
https://cad.onshape.com/documents/c972f05d4ea87d8277c66137/w/a95780126d293c7d78aac831/e/99f3dcf247ec9ed433c58039
Hope this helps for those who work with imported sheet metal models. Can't wait until this will be a command that Onshape will do automatically.
Bryan Lagrange
Bryan Lagrange
@bryan_lagrange
You can select the bends in the faces to convert when you convert to sheet metal.
Also select them in the bends selection box, then they will work like normal bends
EDIT: I see, it doesn't work
You don't have to add your flanges like that though. They can be done in the Sheet Metal Model
Second, as @mbartlett21 said, you can create all the faces in the sheet metal feature:
https://cad.onshape.com/documents/7c05d9bd06c06824fd6ade5a/w/8b8cf0708ba99ecea8a8448d/e/8aea9e6044d09fbc7f522437
Twitter: @BryanLAGdesign
Thanks for pointing this out, this thread has been very helpful for us. The "tangent propagation" option on "Thicken" along with the "edges and cylinders to bend" was designed specifically for cases like this (as @mbartlett21 points out), but it appears that it's not working an intended. Do you all find that often imported models have troubles like this? If so, would you say that you have to use workarounds like this every time, a majority of the time, some of the time, or occasionally?
