How do I select just a corner to be filleted rather than the entire edge?
I need to select the corners of the grip's not the entire edge
Step 18 in exercise: creating multiple parts in a part
studiohttps://cad.onshape.com/documents/e4c0e2d414ee836c98a71240/w/753c3b58f1ac84d191e85444/e/e44d38b59a044a4dbde034e0
If you select multiple edges that intersect. It will give you a soft corner
I appreciate your help
it turns out it was something very simple!
I just had to turn the drawing to be able to select the side edges of it (not the front edge) the instructions picture wasn't very clear
