Some holes not rendering well
brian_wood
Member Posts: 7 PRO
in General
See pics.Most holes in my full assembly model look round. But all of the larger holes on the front bracket, as well as the fan guard, do not. They look fine in the assembly and parts views for those items. Why?
OS adjusts the tesselation values depending on how busy the model is to maintain performance. I'd imagine this is why they look to have fine detail on their own but not as part of a large assembly. It's just the on screen rendering though, the actual geometry is not changed.
Owen S
You might wanna use some renderer for that purpose. But I would agree that there should be a button to set priority on quality with the expense of performance. That could be also option for saved views as screenshots are the main purpose of having better 'work' quality.
Currently the tessellation settings are based solely on model complexity. However, we have plans to take individual machine performance characteristics into account and adjust tessellation quality accordingly.
@brian_wood, Can you please open a support ticket for this issue? You will be notified when we do make changes to improve the graphics quality.
Thanks
Cheers, Owen S.
