Quick design contest
3dcad3dcad Member, OS Professional, Mentor Posts: 2,477 PRO
edited May 2018 in Using Onshape
I don't usually design stuff like this but had to model existing part. Thought it would be 12 minutes to model but found myself struggling with the approach to model it easily so that it could be also produced according to model (I only needed something that looks similar).
Wanna give it a try?
Please reply with a link to public model and screenshot if you like.
It's missing some R but just use whatever that looks the same.
Obviously the word contest means that you should model with as few features as possible and the great reward is .. amm.. errr.. winning the contest!!
I'm sure this will end up with FeatureScript that makes any flange according to parameters with a single feature =)
«1
