https://cad.onshape.com/documents/cda06c69636d0bd302383f35/w/0b8355a9652dc82b891d018d/e/209d3deea9088ff62c0ee41b
There is a few tricks I don't like:
- The variable fillet (there are some room there for a few improvements like ... a fillet feature with several radius
- To avoid the replace face feature I set the width of the rectangle to 38 mm in the sketch instead of 40 mm (because od the draft angle), so I get "more or less a width of 40 in the base
This was fun, thank you
But I don't need an extra feature... just uncheck the Start from sketch plane option :-)
I'm super late but I tried..sorry it's so bad I just started CADing
I don't know If I had the right approach I made the top part 40x40x10mm
https://cad.onshape.com/documents/5bd552dc27785aba4e8a9897/w/5044eee0f5208229b9cf664b/e/eb03387d38960cefc24472f5
