Assembly Total Weight
AuroraRon
Member Posts: 139 PRO
I can assign type of material to a part and get the weight of the part okay.
How do I get the total weight of the assembly?
Is there not a way to show the part weights in a BOM?
john_mcclary
Member, Developers Posts: 4,035 PRO
select as many parts in an assembly as you want, and measure the weight based on what is selected
Or insert the assembly into another assembly, then click the assembly icon in the tree, then measure that5
You should see a message that says some parts have no mass if that is the case
I have also created some stock material libraries now so I can use the material library to find my stock and get the density set based on the material I chose. I.e I have an Australian Sheet and Plate library which list all the different size plates set with the corresponding density, in this case, they are all the same but at least I don't have to think about setting the density.
