Sheet metal templates.
bryan_lagrange
Member, User Group Leader Posts: 802 ✭✭✭✭✭
in General
I would like the ability to select a pre saved sheet metal template that when selected from a drop down list would fill all fields when starting a sheet metal model. You could either enter this information in an area set up for this in account settings or upload the information similar to custom materials are uploaded. To go along with this, if you were starting a new template have the ability to set the material type and after all fields were entered you could save it as a new sheet metal template where you would give it a new name and that information would be stored for future designs.
I logged an improvement request:
https://forum.onshape.com/discussion/9406/sheet-metal-templates#latest
Bryan Lagange
Bryan Lagange
Thank you for this well though IR, I hope more describe their use cases so that we can come up with a universal design.
If this gets implemented, will FS functionality be released?
This is most likely to be implemented on FS side, we'll try to make it as extendable as possible.
