Distributing a series of parts
I have created a design for a large box, the bottom of the box is made up of thirteen boards that are spaced out across the width of the box. The box has a mate connector aligned with a rabbet across the boxes’ width. I then have 13 parts (the boards) matched to the same mate connector using a slider mate.
This allows me to slide the boards into position - there is a slight gap between each board. But the spacing is not easy to get 100% even.
This was a lot of steps and I was wondering is there is a better way to evenly distribute a number of parts along a slider mate
NeilCooke Moderator, Onshape Employees Posts: 5,905
Have you tried linear pattern in assemblies?Senior Director, Technical Services, EMEA5
Can you use Group? If you do not need the boards to move independently that should be perfect.
See above link for an example of linear pattern in assembly.
You will need to mate the "seed" part to the back board you want to move with
best
Steve
Regards
Steve
