find volume of an STL in Onshape?
sergio_cartagena
Member Posts: 2 PRO
When I import my optimized part from Generate (the file is STL) how do I find the volume of it in Onshape?
I think he mentioned it was STL.
He was looking for the volume of a imported part, right?
I have just realize of the STL file is a mesh XD, sorry
When you import STL, it does not import as a solid.
You can use features like konstantin_shiriazdanov has made to convert it to a solid. e.g. Polyhedron FS.
