shape of arrows for diameters
Hello,
I didn't manage to have only one arrow pointing for the diameter dimension as I have for the radial dimension. This would help me a lot to have my drawing more readable.
Thank you
Thank you
NeilCooke Moderator, Onshape Employees Posts: 5,863
@john_mcclary looks like you are using ANSI format - it is not possible to create a diameter dimension with a single arrow in the ISO format.
Senior Director, Technical Services, EMEA5
Odd, I know there was a way to change that, but I am having trouble finding it... I must have early on because mine always show the arrows correctly
@lougallo was there an option removed form the document properties or something?
The only problem is for the printing where the size of the paper is different, but this isn't a big deal
