the assembly studio does not automatically update when previously inserted parts are updated within
larry_ricigliano
Member Posts: 2 ✭
The assembly studio does not automatically update when parts are updated within the part studio? Is there a way to initiate the assembly update when parts have been updated?
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
If the part studio and assembly are within the same document then they will update to reflect the changes. If you are using a linked document, you must create a new version of the linked document and then you can choose to update it in the assembly. If you are still having trouble feel free to create a support ticket and share the document with Onshape Support.5
Twitter: @bradleysauln
Note: when I right-click on a part and select "Change to version", it says "Newer versions available for 0 documents". However, in the history branch manager, it does show my changes.
It would be easier to see what is going on in your document if you post a link to the document on this thread.
