loft using path not working anymore?
Lyle_WalshLyle_Walsh Member Posts: 46
https://cad.onshape.com/documents/5a55a128a3c604c74f83e3fa/w/5fb8568b79431b1f2646ebcc/e/8ee154e52529bb67c270d06d
using loft along a composite curve where the 2 faces to connect are in different planes was working and now it doesnt work, ie document will no longer generate giving me errors I cant understand
"a guide has no adjacent faces to match tangent or curvature to"
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    @Lyle_Walsh
    Try using Sweep, instead of Loft
    Hi, as @mbartlett21 suggest a sweep is good here:-
    Cheers,
    michał_1michał_1 Member, Developers Posts: 214 ✭✭✭
    Only if we would have contol over profile twist along the path, but we don't.
    Good point, I'd not appreciated that was critical here, I's assumed it was a hose guide.  It needs to be a loft then.  Sorry.
    Owen S
    That's just workaround. From feature tree it looks like this loft used to work before, am I right?
    lanalana Onshape Employees Posts: 699
    edited June 2018
    @Lyle_Walsh
    Here is the last state when the loft worked
    compare Shows slight geometry modification of Sketch 8 causing self-intersection in Loft 2. I suspect it is due to the guide no longer passing through a vertex of Sketch 8.
    I suggest using pierce constraint in sketch to tie two curves together.
    thanks for all the help, Lana is right, I see that the curve got moved, thanks Michal_1, that's it!
