loft using path not working anymore?
in General
https://cad.onshape.com/documents/5a55a128a3c604c74f83e3fa/w/5fb8568b79431b1f2646ebcc/e/8ee154e52529bb67c270d06d
using loft along a composite curve where the 2 faces to connect are in different planes was working and now it doesnt work, ie document will no longer generate giving me errors I cant understand
"a guide has no adjacent faces to match tangent or curvature to"
Try using Sweep, instead of Loft
projektowanieproduktow.wordpress.com
Here is the last state when the loft worked
compare Shows slight geometry modification of Sketch 8 causing self-intersection in Loft 2. I suspect it is due to the guide no longer passing through a vertex of Sketch 8.
I suggest using pierce constraint in sketch to tie two curves together.
