Sheetmetal
f2018
Member Posts: 6 PRO
Is there any possible way to make forms or bulges for sheet metal model in Onshape?
Thanks Bruce.Unfortunately what I need was to add some organic shapes
Another option for your model if it is a hybrid of normal sheet metal with organic form on certain faces is creating as sheet metal then use the finish sheet metal command and add features after here but they will not appear on the flat pattern.
By organic shapes I mean body with curvatures and spline, actually I stole that word from Bruce
I will try Exact flat app and notify you back
Actually I was about to try your second method of designing the feature after finish sheet metal command.
Ofcourse I cannot get flat pattern for the features added after finish sheet metal command.
But what I planed was to use feature script 'Flat without redundant edges' which was a failure. So now the only option is 'Exact flat'
Basically it reduces the amount of clicking for a CAM programmer, from which I hear nothing but endless whining where I work
Image 1:
Image 2
