Building a boat
mark_schneidermark_schneider Member Posts: 4
I am new to cad and am trying to build a boat, I copied a design off of the public documents and now am trying to slice the individual parts and lay them flat so I can figure out how much aluminum I need and make templates, or send the a file to a cnc plasma cutter. Do you have any tips?
    edited June 2018
    Hello Mark Schneider - international man of mystery and the tallest man in CAD/CAM!
    Mark, yes - the KIRImoto app in the appstore does this :)
    "Laser mode will intelligently slice a 3D model and layout the cross sections for export to DXF or SVG."
    Philip Thomas - Onshape
    What kind of boat?
    Which public doc are you starting with?
    Can you share your document?
    If you are new to CAD it might be worth doing some of the Onshape stater courses to help you understand the basic concepts then applying that to your bigger project.
  • mark_schneidermark_schneider Member Posts: 4
    I started with a doc called jetboat made by Ryan Verhoest all I am worried about is the hull and the windshield, I could not figure out how to share the file. Thank you for the quick responses.
    @mark_schneider
    Just copy the url in the address bar. Because you are a free user, it will be public already.
    Hi @mark_schneider and welcome.
    A quick read of this would be appreciated:- https://forum.onshape.com/discussion/9107/forum-post-checklist
    There are loads of helpful folks who hang about here, but in the main you'll get much better answers to specific questions.  If we don't know what you know already and what you're stuck on it's hard to offer up anything meaningful.
    All the best.
    Cheers,
    edited June 2018
    Ideally, you would want to use sheet metal to form flat patterns of the parts, but sheet metal only deals with flat folded or rolled parts, not free-form parts of which the hull is mainly made up of. Using some creative sheet metal work individual parts could be created but faces would have to be flat not formed.
    You could also use the flat extract app to get dxf profiles of the faces, this is designed to pull profiles off free-form surfaces.
    Ok so I attempted to use the flat extract app and it won' let me, I'm assuming it' because it' a semienclosed shape. Is there any way to fix this problem?
