Finished Job But Onshape struggles when I make any changes .
Is there a more efficient way to build this project that has about 700 Parts? I am happy with the results but when working with it Onshape seems to struggle a bit. But it does do it.
Would making each rings as a sub assembly create less over head rather than inserting all the rings one at a time from a parts studio.
Any other thought on doing this more efficiently would be greatly appreciated. I do this type of design often and many times there could be thousands of parts.
https://cad.onshape.com/documents/47f8ecb372dd67b4c4fb5112/w/ba34d8bff1f38e186692569e/e/bb40b8d403f52a9e9c3059c3
If you have a lot of the same parts on the same layer, you should look into patterns in assemblies rather than patterning in the part studio.
You may run into a problem with the colored tiles in the pattern, as you cannot skip instances.
If you do not need the whole block to be that color, you could just offset surface by 0" and insert the surface into the assembly and mate it to the appropriate blocks to give it color. Then you will only need to handle 1 or 2 blocks per layer.
Onshape has a tool for debugging model performance.
As you can see that revolved cuts are taking the most time in regeneration. As @john_mcclary
suggested, you can optimize these cuts by taking advantage of your model's rotational symmetry and modeling each color block in each layer only once. Then you'll need to re-assemble them in a new assembly where you can insert as many instances of the parts as needed.
https://cad.onshape.com/documents/f8aa0cc3c7c0f3c52f2e46d3/w/e98b6aaaef7f5c3d32748697/e/198293832cc23971458817de
If you had a simple Step by Step on what you did it would help a lot. I know simple is the wrong word. My problem is I need the original assembly and parts studios to create my drawings of each ring and the full assembly. Do you see your method being used here before the profile cuts?
https://cad.onshape.com/documents/47f8ecb372dd67b4c4fb5112/w/ba34d8bff1f38e186692569e/e/baf4809362b58ee40a2ec789
Then you will have the pre-machined version and the final render version just by clicking the checkbox
When you insert the parts into a drawing you will need to set the configuration while inserting into a view (or change configuration in the view by right clicking the view)
check out this video https://www.onshape.com/videos/configurations-in-onshape
