Linked Document
breno_cruciolibreno_crucioli Member Posts: 5 EDU
In my current document, I have a subassembly where linked documents are located. This subassembly is located in my Main Assembly. When I create a new version of the "linked document" and update it in my subassembly, it works perfectly, but when I open my Main Assembly the changes are not there. Why does it happen?
  • andy_morrisandy_morris Moderator, Onshape Employees Posts: 87 image
    Hi Breno,
    Did you create a new version of the sub-assembly?
    Regards,
    Andy
    Andy Morris / Head of Product Design / Onshape, Inc.
  • breno_cruciolibreno_crucioli Member Posts: 5 EDU
    Hi Andy. No, I didn't. My subassembly is not a linked document, it is an assembly inside my Main Assembly.
  • lanalana Onshape Employees Posts: 746 image
    @breno_crucioli
    We should be able to help if you publish a link to your document.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,996 PRO
    edited July 2018
    I cannot re-create this behavior unless i set the subassembly to a version as well.
    Are you sure your sub assembly isn't set to a version of the main document?
    Try setting a new version in the main document (that holds the assemblies) and see if you get the blue link on your subassembly
    lana said:
    @breno_crucioli
    Hi lana, it is not possible because my project is Confidential. Thank you for your help.
    Hi john_mcclary. I tried to create a new version of my document as you said, but my status doesn't change. The think is, when I create a new version of my "linked document" the blue link is available in the "linked parts" inside my "subassembly". But when I click in the Main Assembly (inside the same document) the changes of my "subassembly" are not there.
    If your document is confidential you will need to submit your question using the feedback tool in your document
    edited July 2018
    There is no "Feedback" tool, there is "Report a bug".
    Could be because you are EDU, I'm sure it's the same thing
    It's ok. Thanks for your help, I'll try it that way. I was not sure if my question was a bug or just did not know how to use Onshape.
