Equation confusion
paul_bartlett
Member Posts: 91 ✭✭
Neil Cooke redid did one of my projects and used Configurations which I have come to like a lot. He used these equations which I haven't seen before, can anyone explain how it works. It looks like it changes dimension or others into a 1 entity and it can be controlled by a quantity number
What is the (x) in the equation mean. The reference is in sketch 1.
https://cad.onshape.com/documents/5cf4172903e955c79db77c3c/w/cc01f0c427133ecefd0ac5da/e/a99e926d639e3febd3780109
number. Wha
number. Wha
Optionsjohn_mcclary Member, Developers Posts: 3,904 PROThe "X" is just an icon to let you know it is a variable in the feature tree.
You will reference these variables in dimensions or features by using the name with a # in front of it ... example: #Rotations*2
He has those variables "rotation" and "Blocks" set to a configuration. So you shouldn't modify them directly.
Instead modify them through the configurations tab (circled in green)
I'm not sure why he has this check set to 1, as that fails the pattern.. unless for any value where blocks is fewer than 5 he doesn't want that pattern to calculate? I'm sure that should read "#Blocks < 5 ? 2 : #Blocks"
6
Seems to me having red on the tree could have unintended consequences on later features.
I know Onshape handles failed features differently than SW, but it's always been taboo to have a red tree.
+1
