Ball and socket restriction
Reece_Isaac
Member Posts: 36 ✭✭
Hi, I have a problem where I have a ball and socket but I want to restrict rotations to only the X and Y axis. There is a pin in the socket running a slot in the ball. I don't understand how to restrict rotation around the Z axis to give my assembly the rotations I want. I have tried using revolute mate connector in the middle of the ball but I haven't been able to change the axis on it (Z) to X or Y. I was thinking I might be able to apply two revolute mate connectors to achieve the rotations I want. Is that a viable method and I just haven't know how to rotate the mate connector?
Any advice?
Thanks.
Any advice?
Thanks.
If you post a link we can take a look and advise you further.
Also, are you based in Victoria? The V line train sort of gives me that idea.
Bruce
Yes, I am from Ararat.
Ah, We've met at Hawthorn at a user group meeting, I'm still wearing the Tee shirt!
To get your part to work maybe you need to combine the ball mate with a tangent mate. The tangent mate might also need a dummy surface or sketch to define the travel however I am struggling to see what you are trying to achieve.
Add a screw relation to the Cylindrical 2 mate:
This will make the screw move up&down when you turn the thread. You have to enter the pitch:
Also, in the future, before you share:
-Click on version and name "V# before I shared"
-Branch that version and call it "others input"
Then give me edit rights to your design, this way I don't have to copy your design and I can fix many things for you.
If you like it, merge the "others input" branch back to your main branch. If you don't like, then delete the branch.
One thing that you need to realize, the version "V# before I shared" will never change and you'll never lose it. What I'm recommending isn't a security risk.
You can always change the edit rights at any time and lock your design down.
Welcome to modern day CAD!
Hit ctrl-d on your keyboard and check the ping rate:
I live in the country and suffer from a good internet connection. It could just be my computer/internet.
