Quantity Reference in Title Block
GWS50
Member Posts: 491 PRO
I have a Title Block with a 'Sheet Reference- Quantity' but I can't find a quantity field in the part properties dialogue box. Could you tell me where I might find this please
Quantity under sheet-reference doesn't appear to do anything that I can tell.
A part's qty is defined by the assembly it appears in. If it is in multiple assemblies, or used in another document, then it's proper quantity cannot be tracked.
Instead what I do is add a custom property to the part and copy the quantity information in the BOM. Then reference that on the sheet.
The reason for that is I can show both quantities side by side in the BOM and double check all of my drawings and make updates in a quick table view.
