Sheet Metal options?
Member Posts: 145 PRO
I need to be able to create a flat part, make some cuts either by laser of punch, roll it, then add an emboss feature after it is rolled.
Does Onshape have this ability?  I can find where I can create a rolled part from a sketch, but I can't convert a solid into a rolled sheet metal part.
In the image below, I have a flat part, that I want to roll into the shape in the background. The of course comes the emboss feature...
Thoughts?
