How do I curve in a draft?
ivan_tan_yi_heng
Member Posts: 1 EDU
Hi, I'm trying to model Ghal Maraz in Onshape but I've run into some problems.
This is Ghal Maraz upper portion. The neck/throat of the hammer curves inwards as it converges into square.
I've been trying to get the draft to curve inwards but I can't seem to be able to do it. I've tried loft but that ended in a failure.
Any suggestions?
Any suggestions?
https://cad.onshape.com/documents/f5c7e315a4f99b7f4ebb449f/w/71a7dae5253b35558b3c6e90/e/f3b6dbbbfb3e4fb72914f11f
