ISO fit marking to dimension
JJVi
Member Posts: 3 EDU
Currently dimensioning tool is not suitable for standard ISO fit marking. Marking can be made as described in picture a, but major drawback is, that dimensions does not follow geometry changes. Also there is no possiblity to use standard deviation dimensions, picture b), because OS added dimension "automaticly"...even it has taken away. Also standard tolerance fitting values would be great.
a)
b)
a)
b)
We have just delivered 450 x drawing sheets which each have at least 15 ISO tolerances which have all been looked up and typed manually.
In the future this should be input at modelling level so that CAM can pick it up straight away and also carry through to the drawing sheets.
https://forum.onshape.com/discussion/8852/automatic-dimensioning-tolerance-fit-tolerance
https://forum.onshape.com/discussion/18601/iso-286-tolerances-in-drawings
