Release Management Customization
adrian_vlzkz
Member, pcbaevp Posts: 297 PRO
In order to align Workflow with existing Processes at a company Release Management. I know this has been mentioned before, just wanted to formalize it as an IR and provide some wish-list features:
-Customize Workflow
-Add States and Transitions
-Add Workflows and jump handlers
-Rename State/Status
-Allow/force scheme for Version Numbers
-Customize Revision Scheme
-Allow multi-level schemes ie. 002.A
-Dynamically transition and increment schemes levels
-Set rules for events
-Customize Part Number Scheme
-Allow Multiple Schemes
-Allow Multi-section schemes (Currently only two,
- XXXX-YY-1234
-Formal Selection of Separator between sections (Dash, Comma, Space, Underscore, period, etc...)
-Allow Sections to be linked to a Property in the component
-Release Candidate Dialog
-Automatically assigned Approver based on criteria (Project, Team, Label...)
-Automatically Assign Released Name based on rules or scheme (think Change Order)
-Other
-Ability to Lock/Sync between Model (Part or Assembly) and corresponding Drawing
-This ensures the sync of Revision counter
-Customize Workflow
- XXXX-YY-1234
-Other
CAD Engineering Manager
3
As I mentioned, I've heard that most of this were in the works, but not sure how one could do something to help them get prioritized.
Any possibility us curious critters could get road-map visibility? Similar to what Office 365 does would be nice:
https://products.office.com/en-us/business/office-365-roadmap?filters=
I made a custom scheme that's formatted "0.00" so that anything after the decimal is a minor release, like a 3D print, and anything before it is a major release, like an official design review or placing a PO for a part. As it stands now, if I release my top-level assembly in a major release, then I'll have to manually go to each part and increment the number to the next major release number (i.e. 1.00 instead of 0.01, which would come up automatically). It would be awesome to have a way to tell Onshape that I want this whole release to be "major" or "minor".
Anybody else have a good system figured out? I'm definitely still learning a lot and working on mine.
Every major release you would need to type in the first B01, C01... or you can do it the other way around to 001A, 001B, 001C....
