Onshape laggy?
duncan_lane
Member Posts: 2 ✭
Whenever I use Onshape it is very laggy, if I move around my design it takes about a minute to load and whenever I click on a line or object it comes up with the message "One Moment...". It then stays on that until I refresh the page. I have checked my internet connection and it is very strong. My laptop also has a good graphics card and CPU processor.
Just wondering how I can fix this problem?
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
I would start off by checking out this page: https://cad.onshape.com/check
Your internet connection has little impact on what you are seeing on screen as the graphics are handled by your local hardware. A lot of the time graphics cards don't prioritize the browser as it wants to have resources available for installed applications. You can go into the setting to make sure the browser is a priority.
For that Onshape check page, I get around 30 million triangles/second on a 2015 MacBook Pro so anything above that should be good. We also have a few links on that page to help sort out the graphics cards.
If you want Onshape support to help out and take a look, you can fill out a feedback ticket and share the document with support.5
Twitter: @bradleysauln
