Onshape laggy?
duncan_laneduncan_lane Member Posts: 2
Whenever I use Onshape it is very laggy, if I move around my design it takes about a minute to load and whenever I click on a line or object it comes up with the message "One Moment...". It then stays on that until I refresh the page. I have checked my internet connection and it is very strong. My laptop also has a good graphics card and CPU processor.
Just wondering how I can fix this problem?
    AuroraRonAuroraRon Member Posts: 126 PRO
    You are not alone. I have been noticing Onshape performance go downhill over the past year.  No matter what browser, computer, internet speed or provider I've used, the result is the same.  Slow, failing to load and their servers failing to respond.  They called drawings "resource heavy," but their examples in advertising and blogs seem far more complicated.  I've asked if they can share one and show how anyone else can do the same outside of their internal network and its fallen on deaf ears.    The image below is an example of what I see on a regular basis.
    Hi @AuroraRon , Are you logging these slow documents with support?
    I have in the past and nothing changes.   It's never resolved.
