Sketches "Final" button improvement
Ed_McGuireEd_McGuire OS Professional Posts: 24 PRO
While working on a Part Tab with many parts.  When I go back and edit the first sketch in the tree, and i use the "Final" button to "see" "after" sketches and parts.  It would be nice to be able to click on points/lines of the "after" sketches/parts to get dimensions to show up in the bottom right corner.  @lougallo
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    @Ed_McGuire That would allow you to reference things that do not exist at the time the feature was created.  That is why we disable selection.
  • Ed_McGuireEd_McGuire OS Professional Posts: 24 PRO
    i understand users may get confused.  yet, for designing, i would find that very helpful.  maybe that can be looked at to have an option for professional users to switch that on.  even add a disclaimer if you want.
