Am I being obtuse, or has the Measure tool been removed?
I'm sure I used it when I first started using OnShape. I can't find it anymore. The help files say it should be at the right end of the bottom of the screen, but there's nothing there. Is it only on certain screens? I want to measure some hole diameters on an assembly without going back and editing the sketches. Thanks.
kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565
The measurements should appear whenever you have entities selected in a Part Studio or an assembly.
Example:
Are you not seeing this text in the lower right corner?
5 -
diane Onshape Employees Posts: 2
Hi - The Measure tool appears automatically when you have something selected (that can be measured) in a Part Studio or Assembly. I hope this helps. Thanks for asking!
Diane
Diane Amadeo - QA Team5 -
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,145 PRO
Sometimes especially in Assemblies it can become slow and may take a long time to show up.5 -
RChilcoat Member Posts: 12 ✭
Thanks everyone. The help files show a little icon that looks like a pair of dividers, and that was what I kept looking for. I didn't think to just select something on the assembly. Works great. Now back to work.
Example:
Diane
Please vote on this IR if you believe this would have prevented this
https://forum.onshape.com/discussion/10216/visual-aid-for-measure-calculation/p1?new=1
