how to create a NEW document
mac_mcquaidmac_mcquaid Member Posts: 5 ✭✭
I no longer have the blue box in the upper left corner giving the option to create a NEW document.
Anyone else having this problem?
If so, is there a fix?
    I think you should definitely contact support if you are missing that 'Create' button. But first try to shift+refresh the browser, it's most likely that the issue is with browser cache..
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    You might also have some sort of browser zoom activated hiding the left column that @3dcad is showing. Typically a browser refresh or restarting the browser can resolve this.
    Twitter: @bradleysauln
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    We have seeen this pop up from time to time in Safari but typically it was on very wide resolution screens over 2500 ox or so. If the issues persists, use the report a bug tool under the ? Menu
