I have a bunch of _surfaces_... I want to color them all at once
I finally figured out that I have to right (Option) click on the name in the list on the left to get the options menu for appearance... but how do i get this action to work on a few surfaces at once?
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
@Paul Bostwick When you use Feedback in ?-menu, they will be addressed properly and you can follow at [your name] -menu > View support tickets.
From what I have understood feedback is currently the best route for feature request, bug report, modeling question or anything closely related to the software.
//rami5 -
abefeldman Member Posts: 166 ✭✭✭
Paul - there is indeed a feedback tool which you can access from the ? dropdown menu. Upon submitting feedback (or a bug) you'll receive emails from Onshape development letting you know if/when your improvement has been implemented or your bug has been fixed so you can go check it out. You can also view tickets you've submitted by clicking your name in the top right and selecting "View Support Tickets."
@Andrew_Troup - @LouGallo and I have been discussing some other improvements to the forums that might allow for tagging bugs and improvements the way you described, but for the moment the best way to bring a bug to our attention is to go through the feedback tool. You could also mention us in a forum post, but that's less ideal...
Abe Feldman
UX/PD/Community Support5
If you select more than one surface from the surface list, the changes in the appearance menu will apply to them all. For fast selecting, you can use SHIFT+click to select everything between the two surfaces in your list similar to how file explorers do it.
1. Have a bunch of surfaces created and expand the surfaces list.
2. Select the first surface you want to change the color of in your surface list.
3. Make subsequent selections of which surfaces you want to change the color of. Left clicking on unselected surfaces will add them to the selection. SHIFT + click will select all surfaces between the last clicked surface and the shift-clicked surface. Clicking on an already selected surface will deselect it.
4. Right click on one of the surfaces and choose "Appearance..." in the context menu. This will bring up the appearance menu that will control the color and translucency of all of the surfaces selected.
5. Change to the new desired color. All of the selected surfaces will update with that color.
LearnOnshape facebook group
However it seems (at least in this stage in Onshape's development), once bugs are reported (ideally by raising a ticket) they tend to get fixed so quickly that it seems to me the info would quickly become superfluous, and spend more time confusing us than clarifying things.
Perhaps a more dynamic tagging system would serve the purpose, by enabling a bug tag to be amended to a 'fixed bug' tag. But if the forum software is off-the-peg rather than bespoke, that may not be an option ...
I'd be willing to (if the convention was established, and I evolved a bit more as a user) to "own a bug" as a user and occasionally be prompted to review "my bugs" and retire them as appropriate. I don't think I have my arms around the product well enough now to do that.
When you wrote, "(ideally by raising a ticket)" were you speaking generically or is there a reporting feature I have missed?
