2D Drawing- Dimension between two concentric circles.!!
VaishVaish Member Posts: 15 PRO
Hi. I am trying to make a drawing of a simple hollow cylinder and would like to show the dimension of distance between two circles, but I can't seem to. The only way it lets me dimension is two circle's diameters individually, but this is not how I want to represent.
Pls help, thanks
    edited October 2018
    @Vaish
    I found a workaround if you mean something like this:
    First draw a horizontal line over circles (it doesn't snap), then drag endpoints to circles (now it does snap), then do the dimension, then delete line.
    A bit of a hassle for small thing but seems to work.
    @NeilCooke
    Way too easy  :|
    New T-Shirt caption?
    It's gonna take like 8 months before we need t-shirts again in Finland..
  • VaishVaish Member Posts: 15 PRO
    edited October 2018
    @NeilCooke Doesn't seem to work, you mean holding shift+q after pressing the smart dimension??
    It works, thank you all for the answers
