'Bulk Update' to a version
iain_downs
Member Posts: 42 ✭✭
I have around 20 part studios in my document, all of which are driven by properties in a FeatureScript object in the document. Then there are half a dozen or so assemblies and a couple of drawings.
When I make a change in the Feature Script (to correct an error or to feed some parameters to a new Part), I have to create a new version and then go into each tab and update the version. This is a pain.
Is there any way of saying 'update all parts in this document'?
Iain
Iain
In the meantime I will keep my mouse finger healthy.
Iain
If I recall correctly there has been discussion about this earlier - I suppose when linked docs came in, couldn't quickly find the link here though..
You should be able to run the latest change to the FeatureScript if it is in the same document.
To update your features to main, right-click on the feature, then select "Update all...", select "Selective update", then select the version tree icon, then select "Main". You should then select "Update selected" at the bottom of the dialogue box.
