Note Box Alignment on Drawings
S_Regula
Member Posts: 95 PRO
Is there an easy way to align 2 or more Note Boxes (either horizontally or vertically) on a drawing?
PeteYodis
Moderator, Onshape Employees Posts: 575
We have planned improvements for note snapping behavior. There are more scenarios to solve for and provide snapping for when you consider multi-line notes and also justification options.5
this will move the text when the line moves.
you can then delete the line when you're done.
this works with balloons too
hmm.. after playing with it for a bit, I can't find a way.
Time to write up an improvement request
