Using point pattern in asemblies
Benjamin_Dellal
Member Posts: 8 PRO
Hi,
I need to use @cody_armstrong 's point pattern in an assembly to replicate parts.
Did anyone figure out how to?
You can't use it in an assembly. You can vote up this improvement request for custom features in assemblies:
https://forum.onshape.com/discussion/9663/featurescript-for-assembly#latest
Have you tried the replicate command in the assembly?
I have an assembly that is using 100x the same part. I am currently in the process of migrating our CAD model from our Catia platform to Onshape.
In Catia, I am cheating: I made a single part, in a single body and used "user pattern" to replicate it based on a point cloud that sets their positions. I manually correct this on the BOM later.
I can not find any good way to do the same in onshape.
Workflow: Import catia part into part studio. Import dxf into a second part studio, add a mate connector at each point. Bring the sketch into an assembly and mate part to mate connector at each sketch point.
Onshape, Inc.
I found a decent work around for now:
The part that mates to all 100 parts has locating holes for these. After constraining one instance, I can use the replicate command as if my parts were screws.
But, I still need to find a better way and using the point pattern in as assembly would be ideal.
Onshape, Inc.
