Circular Pattern (Faces) keeps failing
HI
I am in the process of building http://www.john-tom.com/ElmersEngines/11_Radial.pdf in OnShape.
For the CrankCase I thought I would Create all the features in one section and then pattern them round another two times. Seems like circular pattern should be able to handle that!
However, in short, it fails...
I need to pattern the selected faces onto three faces at 120deg to each other
http://pasteboard.co/8xsIJlr.png
I can pattern just the big hole
or
just the 4 holes around the big hole
but if I select the big hole and the 4 holes or the intersecting holes on the front face then the pattern fails.
At the moment I've done two separate patterns which is ok (but not ideal) but have been unable to patter the intersecting holes.
Any thoughts on how to get this working? or am I down to creating the holes that won't pattern separately
Shep
or
Shep
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
@Shep Face patterns can be very touchy.. Where those intersecting holes come into contact, are you sure you have all the faces in there selected? There might be some sliver faces that are being missed. I can look at it if you share it with support. You can hit Share and click on the "Share with Onshape support" link at the bottom and I can look closer if you like.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
It would have been cleaner (less features) if I could have patterned all the holes in one operation but what I have will work!
And yes one of the problems was not selecting the bottom of the hole although without the rollback it still wasn't working, Maybe a more helpful error than "check input" would be of use there.
Thanks for the help.
Shep
