How to enable default setting for subtitle and speed for tutorial videos?
anugrahandi
Member Posts: 2 PRO
Like in the title, how to enable default setting for subtitle and speed for tutorial videos?
Because I moving from other cad system, i need to watch all tutorial to get a good grasp. However, I can't change default for videos subtitle and speed.
Do I need to change my browser setting? if I use youtube, usually it set the default to the last setting.
Thanks,
Andi
Thanks,
Andi
The self-paced courses in our learning center have this built-in:
This is definitely the recommended way to go when moving to Onshape from another CAD system. We also have instructor-led training under the learning center that you can sign up for as well (I'm not sure if the recordings have these options @KatieHuffman)
The section you might be looking at is from our website video library which houses all of our live recorded content like webinars that may cover some training information: https://www.onshape.com/videos/. These videos will only have the option to change video speed under the gear icon on the right.
Twitter: @bradleysauln
